23-01-2019 01:11 PM
That's what I mean by distortions
Recently I started experiencing a weird issue with my tv (model UE40MU6120KXXU), I either experience random short (1 - 2 sec) blackouts or distorted frames. It happens when using my pc and the blackouts affect menus as well, so I'm assuming it's not an issue with my computer. I plugged in my pc to a different tv, it was fine then. I tried changing hdmi ports on my pc and tv, and tried different cables, without any improvement, I tried updating my tv to the newest version (1262.0), changing the resolution to 2k and 1080p, and changing the refresh rate to 59Hz, but with no effect as well. Also when I turn my tv on, I have to change the hdmi port to a different one to see any video output from my pc. What can I do about it?
Solved! Go to Solution.
28-01-2019 09:57 PM - last edited 28-01-2019 09:58 PM
I already tried it, and it didn't work, but I don't have the issue anymore, surprisingly, reinstalling windows on my pc fixed the problem. I have no idea why an issue with my pc caused the whole tv screen to go black, including menus, but the issue is fixed now.
28-01-2019 06:55 PM
Hi @Szymon_ilnicki.
Are you still having this issue? If so, it might be worth resetting your TV to see if that helps, but first, could you check the software version your TV is currently on? Go to Home > Settings > Support > About This TV.
29-01-2019 10:56 AM
That's great to hear, @Szymon_ilnicki! Thanks for letting us know.
