19-11-2020 04:12 PM
I bought a Samsung TU7000 TV. I wanted to connect to that TV with Panasonic HTS via HDMI ARC. But TV's Sound menu not display HDMI. Please solve this problem.
19-11-2020 04:21 PM
19-11-2020 04:23 PM
19-11-2020 04:31 PM
@Sanjeewa_Samanpriya1: Can you double check to make sure that the HDMI cable is connected to HDMI ARC port on both the soundbar and TV, then head to Home > Settings > Sound Output to see if you're able to select the soundbar from there. I'd also recommend reaching out to Panasonic, or referring to the home theatre system's user manual, as you may be required to establish a connection via the soundbar first of all.
20-11-2020 12:48 AM
panasonic home theater systems (sc-xh105)
20-11-2020 12:52 AM
Problem is not see sound output device. I double check all the settings and cable.
