TV has no display (changed 'DIMM TYPE')
(Topic created on: 15-01-2017 11:22 AM)
CD93
Hi there,
My Samsung TV has been displaying a solarised/negative picture.
In an attempt to resolve the issue I tried to check and change the DDR setting.
Instead the DIMM TYPE setting got changed (INT>EXT) and the display went completely black. The LED is responsive when I press buttons on the remote but nothing appears on the screen.
Any ideas how to help would be massively appreciated.
Thank you :smiling-face:
CD93
3 REPLIES 3
AntS
Hey there, CD93. :smileyhappy:
What's the model code of your TV?
RufusThomas
I have the exact same problem, including the color issue.
I saw this tutorial for fixing the issue:
https://www.youtube.com/watch?v=Q1bg9qP_qic
In which the guy restored the colors by changing the 'DDR' setting in the service menu to 'Samsung'.
Anyway, trying to follow his advice I couldn't find 'DDR', but I though for a moment that the 'DIMM' [Dual in-line memory module as I understand] option might refer to the same thing, so I changed it [int to ext, or vice versa, not sure], and now the TV doesn't turn on at all. Only red LED comes temporarily off for a few seconds when switching on, exactly as the person above described.
My TV model is LE40A450C2XXC
ChrisM
SuperStar
Hi @RufusThomas.
We'd suggest having a word with one of our Audio-Visual specialists regarding this. You can contact them on the number found here: http://www.samsung.com/uk/info/contactus/
