TV bluetooth has too much latency
(Topic created on: 24-09-2020 07:05 AM)
markusss
NU7455 TV
If I use Bluetooth speaker, I can see how the audio will not play at the same time with the image. Latency is short but too noticeable.
The same latency is with Bluetooth devices such as with Bluetooth gaming controller. Using SteamLink and Bluetooth controller makes playing uncomfortable when controller has too much latency. PC is connected with high speed LAN cable, so the latency between computer and TV is not the issue. Checked this from Steam's information.
Is there way to make Bluetooth "faster"?
2 REPLIES 2
Woody9169
I'm also having problems with latency using a bluetooth controller. Far too laggy to game properly. Seems lots of others have issues too after a quick look online. I have the new-ish Tab A 10.1. I've submitted a fault through the members app so fingers crossed they actually address the problem in an update sometime this century.
markusss
Fingers crossed! You have a tablet so you have bigger change to get a fix with update unlike my TV which has a small memory space and TV is 3 years old so it will not get updates anymore (because Samsung)
