26-05-2021 12:36 AM
Hi everyone!
We got 2x The Frame 65" 2021 and 2x Xbox Series X.
Two days ago one frame suddenly stopped working with the HDMI "Game Port".
The day after the other one experienced the same and now none of the TV's HDMI "Game Port" works with the Xbox. TV's just displays a "check input power source" message.
Connecting the XBOX to another HDMI-port works fine.
I checked the latest firmware @ Samsung support page and it says 1506 was made available last week, so my hypothesis is that it breaks "HDMI Game-port" functionality when using the xbox series x 4k/120hz.
I've played around with disabling VRR, HDR etc. on the xbox to no avail. Also had Samsung support remove into the TVs and first reset EDID(?) and then full factory reset.
Didn't fix the issue.
Currently using another HDMI for the Xbox but would prefer to get it back into the GAME-port as this supposedly provides a better picture and VRR-support etc.
Anyone got ideas?
Solved! Go to Solution.
01-01-2022 04:28 PM
Unfortunately I can't find that update on the website only the 1901. Which didn't fix it for me
01-01-2022 04:34 PM
I have just downloaded 1808.1 and it does now work
01-01-2022 04:40 PM
How do you get this update? I’ve seen on the website but I only find the 1805.4 version.
01-01-2022 04:53 PM
01-01-2022 05:00 PM
This update did not solve the problem for me. Are you in 4K HDR 120hz?
01-01-2022 05:05 PM
01-01-2022 05:07 PM
It just does the same old thing for me.
As soon as the tv detects that the device connected is the Xbox it black screens and then tells me the Xbox isn’t turned on. No idea how you have managed to get it to work
01-01-2022 05:14 PM
01-01-2022 10:29 PM - last edited 01-01-2022 10:33 PM
In theory you can try to disable auto-detect. It made my HDMI 4 able to display almost as good as HDMI 1-3. No HDMI 2.1 at all tho. 😕
"Secret" code for disabling auto-detect (must be done when TV is switched to TV channel, not HDMI input).
Mute, Volume Down, Channel Down, Mute
Needs to be done fairly fast to work.
After all patches, HDMI 4 is possible to be used almost as good as other slots, but in the end its still useless cause for me its definitely just HDMI 2.0b. And it tends to black out now and then (not so stable).
Using 1808, nothing newer than found so far (EU model, so outside firmware doesnt work anyway).
03-01-2022 11:58 AM
I have version 1805 and am trying to download 1901 Firmware. When I connect USB to TV and try to update, TV says that there is no new version available!
Help before i kick out the TV ...
