Sonos listed as input
(Topic created on: 26-04-2020 04:04 AM)
Trax95008
I have a Q80R, and when I change the input, I see all my Sonos speakers (several) listed. Is there a way to remove those from showing up there? It's really annoying when I change inputs I have to cycle through all of those speakers to circle back around to the input that I want
11 REPLIES 11
davesomers
did you ever solve this?  I've just setup a new tv and have the same issue
Trax95008
Look to see if there is a firmware update available for your TV. The issue suddenly went away one day, and I suspect it happened after the TV did an auto update
davesomers
the software appears to have been updated as part of the initial install, so that's not solving it for me.  Still looking...
Trax95008
The issue is back. I’m not sure if there was another TV update, or possible Sonos update, but I now have all my Sonos speakers listed again! I wish this would get resolved
ChuckD
Has anyone figured this out yet? I have the same issue with 11 Sonos inputs!
Je idb
same for me.
very annoying!!
bena_2008
Yes, me too Q80 75...   and I have three rooms f Sonos, and each speaker is listed, what a pain.  How can these sources, be hidden, removed, so when selecting a source, the list is only true sources????"??
tychop
I spend hours finding a solution. In the end I binned all Sonos speakers, subs & soundbars.
Baked Bread
Experienced same…On another site I saw what seems like an obvious solution..put the TV on a guest network
