connect Samsung tv with only hdmi/arc out to SONOS playbar with only optical input.
(Topic created on: 26-08-2024 04:09 PM)
jimkehoe
I am trying to connect a 2024 Samsung 65” DU7100 Crystal UHD 4K HDR Smart TV, model number UE65DU7100KXXU to a SONOS Playbar.
The issue is the TV only has audio out via HDMI (ARC) but the SONOS Playbar only accepts sound in via an optical cable.
I assume I need a converter. However there are numerous options on Amazon or similar.
Can anyone recommend one that they use in same circumstances and definitely works ?
Thanks in anticipation.
0 REPLIES 0
