Smart Hub continually updating
(Topic created on: 04-10-2018 04:16 PM)
timjane
My TV (UE37ES6300) is constantly (ie. every day) trying to update the Smart Hub.  As part of the update it will turn off the TV and then start updating again after turning on.  This will happen 3 or 4 times before I am able to use the Smart Hub.
I've tried resetting the Smart Hub and the whole TV, but same thing happens each day
Any suggestions?
4 REPLIES 4
ChrisM
SuperStar
Hi @timjane.
Have you checked to see if all the T&C's have been accepted? Go to Menu > Smart Features > Terms and Policy.
Let us know how you get on.
timjane
Hi,
thanks for the reply.
I think they are accepted - at least there's no option to accept anything, it just lists the wording.
I got to it via Menu -> Suport -> Smart Hub -> Tools -> Settings -> Terms and conditions
ChrisM
SuperStar
Try a Smart Hub reset, @timjane. This will then give you the option to re-accept the T&C's. Go to Menu > Support > Smart Hub > Reset Smart Hub.
timjane
Thanks - unfortunately it's still in the same cycle of updating every day after trying a reset
