smart hub and apps on a Samsung QB65B
(Topic created on: 28-05-2024 03:28 PM)
Members_9SFcCFp
Hello
We have a Samsung Qb65B in our companyu, but can't seem to find a way to enable smart hub and have apps such as Netflix enabled.  Is that possible with this model?
Thanks in advance
1 REPLY 1
AndrewL
@Members_9SFcCFp: I have looked into this for you, and SmartHub is not available on this model, so you won't be able to download and install apps such as Netflix. If you head to Menu > System > Apps, then you can explore your options from there, however I am unsure of the content based on the information in the user manual (linked below).
https://www.samsung.com/uk/support/model/LH65QBBEBGCXEN/
