Go to solution Solved
Sign language problems
(Topic created on: 24-01-2023 09:36 PM)
JJB
Pioneer
Sign language is on BBC iplayer?
How do i turn it off please.
JAMES4578
For reference sign language can also be turned off by clicking Sign Language underneath the playback screen.
There are a number of signed programs available ( obviously does not suit those who do not need the service but wide access is important) See information here https://www.bbc.co.uk/iplayer/help/questions/accessibility/sign-language
5 REPLIES 5
maggie m
Pioneer
You can turn it off by hitting “Turn off Sign Language” on the white banner.
JJB
Pioneer
Thanks Maggie, we have since discovered it was only on the one programme. Everything else is fine x
JAMES4578
JJB
Pioneer
Thanks James, I didn't realise at the time that there were signed programmes as standard. All good now 👍
JAMES4578
No problem, as long as it is sorted.
