29-08-2021 06:04 PM in
TVHi, I have just purchased the Samsung QE55QN94AATXXU and would appreciate if anyone could share the settings they have used. Also would anyone in the forum recommend an HDMI cable for this TV. There are so many to choose from and I want to maximise the best picture the TV can offer.
Solved! Go to Solution.
30-08-2021 01:01 PM in
TV31-08-2021 05:36 PM in
TVHi Ginga_p, thanks for this update, I have ordered the cable you suggested from Amazon, arrives tomorrow.
31-08-2021 07:09 PM in
TVHi James thanks for your very comprehensive reply, both articles were very interesting to read. I never thought there so much to HDMI cables, I have always had a couple "lying" around the house and would use when required. Ordered the Ibra from Amazon.
The writeup on the QN95A is also interesting, not sure if there is much difference from the 94A. I know it has the connect box but the additional £100 was just outside my budget. I will look in more depth the various settings in picture modes to see which one suits my viewing,
TV30-08-2021 02:54 PM - last edited 31-08-2021 05:49 PM ) in
TVHi @agh551 You could look at this article for general advice https://www.flatpanelshd.com/review.php?subaction=showfull&id=1623645585 I do not have one of the latest models but I think Standard and movie modes produce the most accurate picture for Tv viewing. There is a filmmaker mode on this one but seems similar to movie . Auto Motion plus tends to best at low or switched off for most content other than sport.
However some experimentation may be requited to suit your own preferences and tweaked for different content.
As far as HDMI cables go 2.1 is required for variable fresh rate ,earc plus 4k at 120 hz. See some analysis here https://www.techadvisor.com/test-centre/digital-home/best-hdmi-cables-3676960/ The Ibra one that @Ginga_p mentioned also here https://www.amazon.co.uk/IBRA-High-Speed-Supports-Compatible-PlayStation/dp/B084L6JWDY/ref=asc_df_B0...
One Ui 5.0,Android 13 .
30-11-2021 06:29 PM in
TVHi - I bought an 5M 8K HDMI 2.1 Ultra HD 48Gbps with eARC and Dolby, its great. Made by Maxonar from Amazon. Very pleased with it, highly recommend and only £29. https://www.amazon.co.uk/gp/product/B08TV27NL3/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
