09-07-2020 09:14 AM in
TVHi,
I can not mirror my Phone(Samsung Galaxy A50) to my Samsung ue32n5302 TV when it is connected to 5Ghz wifi network. I also tried to connect with my laptop trough wireless display but it was not working too. TV is on the latest software level, no new software update is available at this moment.
I spent a lot of time to find solution in the TV's settings menu without success.
After that it came to my mind what if I connect all of my devices to 2,4Ghz network. Suprisingly the problem dissapeared. I could share my phone screen on TV and I was able to connet the TV as wireless display to my laptop as well.
Is there any solution to use the screen mirroring and wireless display function on 5Ghz Wifi network?
Thanks,
Gabor
05-12-2020 09:27 AM in
TVHi,
I was wondering if you had found a solution to this problem?
22-02-2021 11:43 AM in
TVHi,
You found a solution to this problem?
Thanks
22-02-2021 01:12 PM in
TVHi, unfortunately I have no solution for this problem and I havent received any answer from SAMSUNG... 😞
If I want to use wireless display I have to switch back to 2,4GHz.
22-02-2021 05:20 PM in
TVThanks !
Your solution work for me, I found a post another forum about this issue and we need wait for a update, they have problems with the stability of the 5g!
22-02-2021 08:50 PM in
TVDid this post specifically say that an update might sort the problem out do you know?
It's so hard to find information on this...
29-03-2021 05:32 PM in
TVSame issue with SAMSUNG UE55MU6172 😕 Mirror share working only with 2,4ghz
09-06-2021 09:25 PM in
TVAny new info about this? Same problem with M7 Smart Monitor
