Samsung UE40NU7120 - poor picture quality
(Topic created on: 10-12-2018 08:54 PM)
22NG
Really appreciate any advice.
Just set up our Samsung - connected via aerial/terrestial. Picture quality is poor. However, when we go into expert settings-auto correct, the picture is crisp. How can we improve picture quality?
1 REPLY 1
JAMES4578
Samsung Members Star ★★
Hi @22NG,    Generally on UHD sets it is best to use Standard or Movie Mode, whilst keeping Auto processing to a Minimum and defaault settings  may not  necessarily be the best. Whilst precise settings are subjective you could look at some recommendations but these may need to be tweaked to suit your own preferences and it can be a bit of trial and error.
The NU 7120 seems to be little different from the NU7100 and so you could check out these recommendations
https://www.rtings.com/tv/reviews/samsung/nu7100/settings      https://www.engadget.com/2018/03/05/best-tv-settings/
