Samsung UE32F5000AK Black Screen Problem..........
(Topic created on: 04-02-2023 12:24 PM)
magicshaw
Hi,
I have this 10/12 year old Samsung UE32F5000AK that won't power on.  When you press the on button the led blinks on and for SIX times and goes off. The audio of my Sky programe can be heard but nothing on the screen. This issue did pop up few weeks ago but somehow it went away but now the issue is back and the TV won't turn on.
I don't think its a capacitor issue as i've opened it and had an external look at it. None of them are swollen or anything.
Any help to resolve this please ???
3 REPLIES 3
xSteveuk
Mastermind
Hi
Unplug TV
Try disconnecting and reconnecting the HDMI cable.
And is fully fitted and not loose
Check power cable
magicshaw
@xSteveuk
Tried all, the Samsung logo before the start of the TV just doesn't turn up. The screen stays dark but audio can be heard.
Hellpricess87
Did you find a solution? Same problem here but with a difference. I can see the logo then the It goes away but the screen stays on ( i can see backlighting) but the screen Is black.
