Wireless Display (screen sharing) without prompt/answer on TV
(Topic created on: 04-02-2023 07:14 PM)
papadeltasierra
TV
I want to use an AU9000 as a "dashboard", showing a webpage from a PC.  I have successfully connected the two using "Wireless display" but this required me to acknowledge the request on the TV from the PC using the TV's remote .  This is not a good long-term solution for something that is supposed to run with minimal user interaction so either:
1. Can I somehow disable this need to acknowledge the request on the TV or
2. Is there a way to "talk" to the TV using a computer program that will "see" the need to acknowledge and say "OK"?
I am a programmer with 30 years experience so happy to play with whatever SDKs/interfaces Samsung TVs have.  I do know that there is a "remote over a network" at port 55000 but this seems to be "send/response" only and I'm not aware of any "indications" i.e. messages sent from the TV to the PC to say "someone has requested screen sharing - OK?" Does such an interface exist?
0 REPLIES 0
