Samsung UAJ5300AK has optical audio output not working
(Topic created on: 16-10-2022 06:11 PM)
Henroe
Hi. My UAJ5300AK TV has an optical audio output port, but the settings menu does not give me an optical audio output. It only has TV speakers and audio out. So I can't get my soundbar to work via optical audio output. Please help if somebody has solved this issue before.
1 REPLY 1
antikythera
Black Belt
It will only work if the connected device supports the same bit rate and the cable is not damaged. Digital optical audio cables are all or nothing with regards signal transmission. Also, some don't always fit too well due to the thickness of the hand grip above the plug. Amazon basics cables seem the most universal in that sense from experience. Like with HDMI, also make sure the cable is plugged in only when both devices are turned off.
