Samsung TV QN85C headphones
(Topic created on: 01-11-2023 09:28 AM)
Bill Ricketts
Hello,
Ref: Samsung TV QN85C
I have one question that I hope someone can help me with.
I would like to set up headphones to get sound from both the TV speakers and the headphones.  As I'm a bit hard of hearing I can listen via headphones while my Wife can listen through the TV speakers at a volume setting comfortable to her.
Is there a sound setting to choose TV speaker + audio out? Also is there some sort of audio sockets to plug wireless headphones into or would I need bluetooth headphones.
I would be most grateful if you're able to advise me on this.
Kind regards,
Bill Ricketts
2 REPLIES 2
GuzziBoy
Voyager
https://www.samsung.com/au/support/tv-audio-video/multi-output-audio-on-samsung-tvs/
Try this link reference multi audio output. I'm interested as well as I have the same issue and it would be nice to be able to use my headphones or my earbuds Pro. I haven't had time yet to check it out so let me know if it works cheers
Bill Ricketts
So I received my Sony wireless headphones, they had to be wireless as research suggested that wired in options wouldn't work on the QN85C. I went through the pairing and multi option output and sure enough sound came through the TV speakers and the headphones. Problem was that the sound was out of sync so it was like listening to an echo. The headphones are being returned to Amazon and if anyone has any other ideas for a solution please let me know.
