03-11-2022 04:17 PM
Re; TV Model Number LE32A451C1
I am trying to find out if this TV has the facility to enable me to get Digital TV channels from my nearest transmitter. There is no Digital/Analog button on the remote control.My query is, can i get DIGITAL on this TV, and if so, how to i go about it. Thank you.
Solved! Go to Solution.
03-11-2022 06:36 PM
Great, Many thanks for advice and information.
03-11-2022 04:52 PM
Hi @ALL4ONE yes you should be able to receive the Freeview channels on this set as long as you have a aerial connected though it seems to be a 2008 model. you need to search for channels, from the guide:
The message "Check antenna input." is displayed with "OK" selected.
Press the ENTER button.
Please check that the antenna cable is connected correctly.
5. Select the appropriate country by pressing the ▲ or ▼ button.
Press the ENTER button to confirm your choice.
6. The "Auto Store" menu is displayed with the "Start" selected. Press the ENTER button.
The channel search will start and end automatically.
After all the available channels are stored, the "Clock Set" menu appears.
Press the ENTER button at any time to interrupt the memorization process.
see more detail here https://www.samsung.com/uk/support/model/LE32A451C1XXC/
General Freeview information is here https://www.freeview.co.uk/help/location#:~:text=To%20check%20your%20Freeview%20coverage,on%20BBC%20...
03-11-2022 06:36 PM
