Setup of Source Universal Remote (missing)
(Topic created on: 03-11-2022 07:33 PM)
RSLA
When I go to source in settings it doesn't show the universal remote option. As if that feature not available but manual suggests it should be. I'm on an new TU7070 model so should be. Thoughts?
1 REPLY 1
JAMES4578
Samsung Members Star ★★★
Hi @RSLA  Looks like you have changed your Tv. If not available via the Source option unfortunately suggests not available on this model either.
From Manual:
"Universal Remote
You can control external devices connected to the TV using a Samsung remote control. To control external devices,
register them by following the instructions on the screen".
This function may not be supported depending on the model or geographical area.
For more information, refer to "Controlling External Devices with a Samsung Remote Control - Using the Universal
Remote".
