Samsung SolarCell Remote
(Topic created on: 3 weeks ago)
OmegaMutant
Pathfinder
Greetings all,
I purchased the QN90C Neo QLED which was delivered on Sunday.
I've had a quick scout on Google and can't really find anything about it but, the SolarCell remote doesn't seem to get any charge when the panel is facing upwards in both indoor lighting and in sun light.
Has anyone else encountered this? If so, is it just a case it'll take some time due to being solar? Or something else?
Other than that, I've had zero issues with the set up process or using the TV. I can see the difference in quality compared to my old TV (Toshiba) and the soundbar, that came free, is good - I was going to flog it, because it didn't come with a woofer, but so far so good so I've kept it.
Anyway, thanks for reading ☺️
3 REPLIES 3
Gurky
Helping Hand
Odd, I've never popped up pannel up on 3 years and it as 50% the other day.
OmegaMutant
Pathfinder
Tbh, it's more curiosity than anything. I've plenty of battery on the remote, and will just use cable to charge it.
I'm sure I read they're made to last a couple of years too?
MorningBlunt
Helping Hand
Mine doesn't get above 70% or so, I think it's normal.
MB
