08-07-2022 01:31 AM in
TVI've got a Samsung Series 7 TV, and according to many videos, to enable AirPlay you need to get on the "Apple AirPlay settings" but I just don't have that option. Is my TV too old or unable to use AirPlay?
08-07-2022 03:54 PM in
TV@Fares Mikhi: Please can you confirm the model number of your TV, located on the sticker on the back of the device, or in Settings > Support > About this TV? In the meantime, please take a look at the link below for steps on how to utilise Apple Airplay on compatible Samsung TVs.
https://www.samsung.com/us/support/answer/ANS00082643/
I couldn't find anything called a model number but I've found the following:
Model : UA50MU7000R
Model Code : UA50MU7000RXTW
10-07-2022 12:18 PM in
TV@Fares Mikhi: Please be aware that I have removed the serial number from your reply, in accordance with data protection and the terms and conditions of the Samsung Community.
I have looked into this for you, and Apple Airplay is only supported on compatible Samsung TVs manufactured in 2018 or later. As your TV is an MU model, which was released in 2017, then Airplay settings will not be available on your set. I apologise for any inconvenience this may cause you.
