Samsung RU8000 has the ugliest stand/legs/feet
(Topic created on: 05-03-2020 02:58 PM)
ShadowOfDeth
Are there any better looking ones from other Samsung TVs that might be interchangeable?
3 REPLIES 3
AndrewL
@ShadowOfDeth: I would always recommend using the official parts provided with a TV to avoid any potential issues. There's always the option of wall mounting the TV if you're not a fan of the stand. To find out more please check page 11 of the User Manual via the link below.
http://downloadcenter.samsung.com/content/EM/201903/20190319110422429/BN68-09492C-02_URU8000F_XU_190...
JAMES4578
Samsung Members Star ★★
@ShadowOfDeth Doubt other parts are really interchangeable   and  not generally not advisable to use unofficial parts.  If an issue agree with @AndrewL  best to have it wall mounted.   Looking into this perhaps not the most stylish design and   the feet are a bit basic  , you would need need a fairly wide table or Tv stand.
Tactical88
You can buy a TV mount stand from a site like Amazon or eBay. These stands will attach to your TV via its industry standard VESA wall mounting holes so you don't have to worry about it having to be specifically for your Brand/Model. Just make sure the one you pick supports the screen size and weight of your TV, most of them support 32'' to 65'' TVs.
