Samsung TV RU8000 Multiple Audio output
(Topic created on: 09-10-2021 11:25 AM)
tommy2911
Hello,
I have a UE49RU8000U and I just bought a soundbar (Yamaha yas-109).
I'm experiencing some problems to set it up since along with the soundbar I need to use a pair of headphones (sennheiser) connected by bluetooth to the TV.
The problem is that if I want to control the soundbar through the tv I need to connect by HDMI with the ARC port but doing this as soon as I connect the headphones the sound is cut from the soundbar. Headphone only works if I if use the native speakers of the tv or if the soundbar is connected with optic cable. In this case both works at the same time but I need to use a second remote control to tune the sound of the soundbar.
I would like to know if there’s a workaround to use the soundbar with the HDMI while using also the headphones.
PS: I check the manual of the soundbar to see if it’s possible to connect the headphones to it but it seems that Bluetooth works only as input.
Thanks
0 REPLIES 0
