27-12-2023 10:10 PM
Can anybody tell me if the Samsung QE65S95C has freeview built in, thanks
Solved! Go to Solution.
30-12-2023 04:46 PM - last edited 30-12-2023 04:47 PM
OK last post on this subject.
Removed terrestrial aerial then plugged in dish selected Freesat and it tuned in and is working perfectly.
27-12-2023 10:46 PM
27-12-2023 10:47 PM
Tank you.
27-12-2023 11:14 PM
Sorry for another question but does the QE65S95C have Freesat built in
28-12-2023 12:04 AM
28-12-2023 01:13 AM
I thought that Freesat showed free channels that are on satellite. Like buying a Freesat set top box but built into the tv instead of a stand alone box
28-12-2023 05:06 PM
Just an update the QE65S95C does have Freesat built in
29-12-2023 07:56 PM - last edited 29-12-2023 08:43 PM
As I said it does have freevsat onboard BUT IT DOES NOT WORK.
