15-11-2022 12:25 PM in
TVHi all,
Just bought a SAMSUNG QE65Q80BATXXU 65" Smart 4K Ultra HD HDR QLED TV with Bixby, Alexa & Google Assistant, which i must admit is really nice.
I previously had a Samsung and adjusted my picture settings to what i felt was at its best.
This TV don't seem as sharp in HD on my tv viewing which my previous one did.
Anyone got any recommendation to picture settings please so i can try and get the best out of this new one i have just bought.
Thanks
Solved! Go to Solution.
16-11-2022 11:13 AM - last edited 16-11-2022 02:24 PM ) in
TVNo problem ,with a bit of experimentation you should be able to improve the picture quality and find best settings for yourself. Yes I mind you talking about your previous model.
One Ui 5.0,Android 13 .
15-11-2022 07:03 PM in
TVHi @valleyboy22 Whilst can make some recommendations think you need to experiment a bit on a new Tv, preferences will differ. check the sharpness level but generally this needs to be balanced and not at too high a level, if it is set too high you likely to lose detail. Motion processing is usually best at minimum level, for instance Auto Motion plus and Digital Clean View. I prefer Brightness at average level with contrast relatively high. However I do not have one of the latest models. This set utilises the Intelligence Mode but can try out the other settings such as Filmmaker,Standard and Movie. This model seemed to be well regarded in terms of HDR. Can see some details in this article https://www.t3.com/reviews/samsung-q80b-review
There are also some settings advice in Rtings https://www.rtings.com/tv/reviews/samsung/q80-q80b-qled/settings
Anyway enjoy your new Tv
16-11-2022 10:57 AM in
TVThanks for the reply.
I have been playing around with the settings and i will look at the link you sent also. I remember doing Auto plus etc on my last Samsung to improve picture quality, so i will have a look at this to.
21-11-2022 03:42 PM in
TVNot sure how i can eliminate the move effect motion on the tv. Did it on my last one but cant seem to see what i might of did so i can do it on this one.
