Go to solution Solved
SAMSUNG QA65Q60TAWXXY Flickering/restarting
(Topic created on: 09-02-2021 12:01 PM)
iamchrisrayy
Hi all,
Today, my Samsung TV randomly turned off and then started restarting itself, becoming all glitchy and white lines showing on the left side. It won't start up properly and continuously restarts after the QLED icon appears. Any Suggestions?
Screen Shot 2021-02-09 at 10.59.16 pm.pngScreen Shot 2021-02-09 at 10.59.59 pm.png
nowdeleted
Big Cheese
contact the company you bought it from or contact samsung if you think its the TV at fault
4 REPLIES 4
nowdeleted
Big Cheese
check the remote..... no buttons stuck down and change the batteries.. also see if you can do a diagnostic program via the TV settings, also check to see if there are any updates
iamchrisrayy
TV is unusable... it continues to flicker/glitch and then restarts before I can do anything else.
have changed the batteries in the remote with no luck
nowdeleted
Big Cheese
ChrisM
SuperStar
Hi @iamchrisrayy
Have you tried unplugging the TV from the mains for a few minutes before plugging back in?
