Samsung le32c450e1w weak or no signal
(Topic created on: 30-09-2023 11:55 AM)
Members_GAk7Si4
OK I've read the previous posts and so far not coming up with to help.  TV has worked for years even in its new location. but more recently I'm getting weak or no signal problems.
I suspect its the Ant-In connector on the back of the TV which has a fault or dry joint is there anyway of testing this ?
1 REPLY 1
Pugs1957
SuperStar
I guess the best way is to see is to remove the aerial cable and see if it makes any difference. I would also try to connect another TV to the aerial socket. If that works, the issue is as you suspect.
