Samsung Frame Slideshow Issues
(Topic created on: 27-10-2021 05:20 PM)
Stevegw
Slideshow Samsung Frame Slideshow Issue
Hi, this is a continuation of a thread complaining about slideshow issues whereby the slideshow stops and just shows the first image from your pictures.
I will attempt to copy a few of the messages that may have provided an answer
Steve
7 REPLIES 7
Stevegw
OPTIONS
TV
Dear Community,
since I have turned off sleep mode/Movement detection I stay logged in and the Slide Show works.
I don´t know if the same issue is with night mode but I guess everything that turns off the TV logs you out and you have to log in to your Samsung account again to have all features working !!!
Tony Gray
Mine just started doing this a few weeks ago, I'm guessing after a recent software update?  I'll try turning off sleep mode, though my answer so far has been to just manually change the image every few days.
Stevegw
Thanks Tony
When I changed the setting for motion detection to turn off it kind of worked but then the screen Is on the whole time. It’s not very user friendly either way.  Do you update your Samsung TV by downloading on to USB stick. There does appear to have been a software update for ages for my Frame TV
Tony Gray
I'm just doing art mode from the at store, not actually using my own images.  One of the other posts suggested it might be as easy as logging out and back in to my Samsung account, so I'm trying that too.
Stevegw
I think I tried the logging out and in bit but will try it again , thanks Tony
Tony Gray
Confirmed - it may not be this easy for everybody, but all I had to do was log out and back in to my Samsung account through the settings menu and it started working again.  It's back to cycling through the slide show in art mode.
Catdaddy MD
Apparently, something got lost in translation. When you set duration, you and I might think it’d mean how long the entire slideshow would run for.  Samsung programmed “set duration” to mean how long each picture stays up before switching. Therefore, when you set a 2 hour slideshow, it keeps each photo up for 2 hours before switching, hence people thinking it will freeze and stay on the same picture forever.
I just set up my 2021 Frame TV on 8/7/22, and changed the duration to 3 minutes. It changes my uploaded photos every 3 minutes. I hope that clears things up for people; it certainly frustrated me for a few hours.
