22-08-2020 12:34 PM in
TVSamsung Frame 2020 and Sonos Amp connected via HDMI ARC
When I change the sound output to built-in TV speakers in Samsung TV, it automatically changes back to HDMI ARC sound output in a few seconds.
Sometimes I want to use the TV with its built-in speakers, so I don't want it to always automatically and persistently switch to the HDMI ARC sound output.
How can I disable this automatic switching?
22-08-2020 03:59 PM in
TV24-08-2020 04:23 PM in
TVThank you very much for the workaround, unfortunately not applicable to our case, because then we lose the Samsung remote's ability to control the sky box. Also it is complicated for a normal user to go into settings and find and change this setting every time. I hope Samsung fixes this bug. Assuming it is a Samsung bug...
24-08-2020 04:48 PM - last edited 24-08-2020 04:49 PM ) in
TVIn case this helps to anyone, I have contacted Samsung support and they seem to be aware of the problem and in the process of working on a fix. Samsung support rep's response is below:
"I see. Upon checking this is being investigated by our Headquarters and they are now working on a resolution and coordinating with Sonos. As soon as there's a fix on this issue, Samsung will release a new update to fix the fault. The TV is set to "automatically update", once there's a new update/resolution, the TV will be automatically updated.
12-12-2020 02:38 AM in
TVI'm glad there's a DIY patch for this. A bit annoying, but totally worked to turn off when I turned off Anynet. Hopefully Samsung will create an update for this soon, and surprised that more people aren't having this issue.
17-12-2020 09:01 AM in
TVHello, I have still the same problem. I like to be able switching to sony headphone connected bluetooth. Output automatically changes back to HDMI ARC sound output in a few seconds.
I am afraid there haven been an update yet (4 months later) .
Samsung helpdesk: can you help?
19-12-2020 06:42 AM in
TVSo annoying. Not sure if it's Samsung's fault or (in my case) Sonos. Hopefully they'll fix it soon.
19-12-2020 11:20 AM in
TVWhen I talked to Sonos in August (4 months ago), I was told that they were aware of this problem and that they were in touch with Samsung for a Samsung firmware update to fix this problem. I have been away from this TV since then, so I haven't had a chance to check for new Samsung TV firmware updates since then. Assuming people posting in this forum are running latest firmware, looks like we have to wait more...
A known problem not being fixed for so long is not a good sign, hope it gets solved one day...
22-12-2020 12:45 AM in
TVHaving this same problem with the Sonos Arc. Atmos is also not working.
I have the 2018 Q7FN 55”
16-02-2021 04:06 PM in
TVI was able to turn off Anynet+ HDMI-CEC and connect to my Bluetooth headphones (Sony 1000XM3). The problem now is that my Sonos soundbar no longer shows up as an identifiable source. The only way to find it again is to turn Anynet+ HDMI-CEC back on. Anyone know of a workaround? Ideally I'd like to have both sources to choose from without having to go into settings, General, External Device Manager & turn off Anynet+ HDMI-CEC every time. Thanks!
