Samsung 4K TV Dangerously hot in the corner
(Topic created on: 08-04-2019 11:37 AM)
Simon36
Hello, my Samsung 4K flat screen tv has developed a dangerously hot glow in the right hand bottom corner of the screen and a large vertical shadow has appeared. The corner is so hot that I fear it will melt and set fire. I can’t use the television now which cost over £600 just over 2 years ago. This seems to be a common manufacturing error that hasn’t been addressed properly with a product recall.
Can anyone please advise on a solution through Samsung? I’ve been directed by them to a servicing company but they want to charge me for inspecting the television.
Many thanks
Simon
6 REPLIES 6
AntS
Hi @Simon36 . Doesn't sound good that. I'd like to look into this one for you. Can you shoot me a PM with your customer reference number and contact details?
Kelly77
I have the exact same problem with my 4K curved TV. Vertical shadow, whole bottom panel hot to the touch!! Under 2 years old!! This is a serious problem and it does not seem like Samsung is taking it seriously! I was told my TV is not under warranty!! What will it take a fire with casualties? 😡
Simon36
Hi Kelly
Samsung replaced my screen quickly after I mentioned the seriousness of the issue. Their approved engineers came to the house. I’d try again because it’s a potential hazard. I’m sure they’ll help you if it’s the same issue I had. Try messaging the guy who replied to me.
cheers
Simon
Mayank27
Hello Samsung
I have recently purchased Samsung 85 inch TV. Model no QE85QN95CATXXU. My TV is hardly 4 month old and it started getting very hot from one side of TV. I have also heard like cracking noise yesterday. Since then I stop using TV. I am really worried that this TV will catch fire as it getting so hot. Can Samsung please let me know to do with this as it just 4 month old tv.
Thanks
uscachi
My Samsung QN55Q60TA TV is also overheating in the lower right corner, and lines have already appeared on the screen (see photo). I've noticed this is a recurring issue, but what concerns me the most is that due to the high temperature, the screen is starting to melt, which could potentially cause a fire. Therefore, I strongly urge Samsung to correct this issue and recall all TVs with this defect before an accident occurs.
uscachi
TV Samsung QN55Q60TA
