15-10-2020 01:13 PM in
TVHi all,
We have a Samsung 43" UHD (UE 43TV 8500V). My parents are both elderly and its become a major problem for them to move between the terrestrial channel list and the satellite channel list. For a simple description, their two favourite channels are Channel No1 on the terrestrial channel list and Channel No1 on Satellite channel list. On all our previous TVs you could just tune these channels side by side on the same channel list and it was simple to flick between both. Literally one button press on the remote control.
With this Samsung tv, its a number of remote control commands to get between the two channels.
The remote control commands are as follows: 'Chnl-List' -> Left -> Up -> 'Enter' -> select 'Terrestrial'/'Satellite' -> enter ->exit. (that is 6 or 7 presses just to go between one channel and the other).
I really can't believe that Samsung would make it that difficult. Our last tv receiver allowed for mix-and-match list of channels. So my question is their an easier way/shortcut to toggle between the two lists??
It is very difficult for my parents to use the remote as they have bad eyesight. Surely Samsung have better GUI designers as there is a lot of redundant buttons on the remote that are never used.
thanks for your help in advance, the picture quality on the TV is brilliant.
eoin
15-11-2020 10:02 AM in
TVI have exactly the same problem with my parents.... They can’t handle this switching and they have favorite programs on terrestial and satellite channels... on old TV there was no such issue... I cant believe that Samsung did it this way... Did you find any solution?
22-02-2021 05:25 PM in
TVHi
I live in Ireland and just bought the same TV
I cannot believe that Samsung has made this so difficult to switch
Can you use Bixby to do it ?
Dan
23-02-2021 09:19 AM in
TVSorry for the delay.. Unfortunately got no solution yet! I really hope Samsung do something about it, you would think it could be done remotely with a software update, i cant see how its such a problem to mix channels on list terrestrial/Satellite. Seemingly they had it a few years ago until an update removed it
23-02-2021 09:30 AM in
TVHi.. Unfortunately Samsung never responded to me. I didn't try Bixby as my parents don't have Smart phones. I did try macros, which are automatic switching on a tablet, but it was just too annoying also.
I'm just shocked that an interface could be designed so poorly. Very linear without testing in ' a real world' scenario. Every other satellite receiver box /tv I've used has been able to have channels mixed. Seemingly, Samsung had the option to mix terrestrial/satellite on their 'favourites' channel list but this got changed in a update some years ago.
08-11-2021 09:44 PM in
TVDid you guys find a solution?
I'm experiencing the same issue.
10-11-2021 09:28 AM in
TVNo we didn't !!! Samsung have not got back to us either. They have updated the TV list with their new internet tv channels but still have not rectified the mixing of terrestrial and satellite channels . still driving us mad unfortunately .
09-09-2022 12:47 PM in
TVHi All,
I Had the same issue with my Samsung TV and find the solution and I wanted to help anybody searching for
switching between Satellite and Terrestrial channels on Samsung TV
you simply need to hold the "channel changing" button (not press once, HOLD it) it opens another channel list menu that allows you to swtich between Satellite and Terrestrial Channels
Good Luch everybody.
