Samsung 32" screws not tightening
(Topic created on: 26-10-2023 01:29 PM)
Carrollt
I'm trying to put the bracket but some holes won't tighten the screws. Anyone know how to fix this issue.
2 REPLIES 2
LukeB2
Helping Hand
@Carrollt What TV do you have? What bracket are you using?
Carrollt
It's not the bracket, I believe the hole lost its groove to tighten the screws, because one side is fine.
