07-09-2020 03:49 PM - last edited 24-10-2020 10:01 AM
Good afternoon.
ive recently purchased a Q90T. I came from a 2015 Samsung which had no frame rate issues at all.
The Q90T is great in every way apart from when watching Freesat or Now TV. Both of these broadcast in 50hz/50p. So I assume it’s something to do with this frame rate.
what happens is that when there is a small amount of motion on screen such as an interview or no panning etc then the screen shows something similar to the frame rate dropping in half and everything stuttering. Once motion picks up or shot pans around then it goes back to normal.
I had all picture clarity settings set to off but I then played around with settings such as judder reduction and blur reduction etc to see if I could eliminate the stutter but nothing works.
its really bad watching football on free sat or now tv as it’s stutters quite a lot.
weirdly, not all programmes stutter. I’ve watched some catch up tv on now tv as well as movies and these show perfectly without any stuttering and all content on Netflix etc are all fine as well.
I am on the latest firmware.
any ideas if this is common or if there is a fix as nothing I’ve tried works.
thank you
Solved! Go to Solution.
11-02-2022 01:09 PM
Yes that one ,then unzip it to a USB stick .
11-02-2022 01:17 PM
I meant, there is two download options;
1. Upgrade file USB type - All operating systems
2. Upgrade file USB type - Windows
Which one should I use to upload to the TV? Thx!
11-02-2022 01:45 PM
Just read it is both the same file, but depending on your computer OS how you prepare the firmware to the usb.
11-02-2022 01:46 PM
If your computers operating system is Windows, download the Windows file."All systems" is if you are running Linux or Ubuntu etc.
11-02-2022 01:47 PM - last edited 11-02-2022 01:48 PM
How about Mac OS?
Edit: think I comprehend now. Thanks
11-02-2022 07:07 PM
Great news! Been waiting for a fix - however, went to try and find firmware update on line for my model QN85Q90TAFXZA - it said model not found! Any ideas - I'd really like to get this fix in.
11-02-2022 07:09 PM
I have model QN85Q90TAFXZA - went to support and it said model not found! Can I use firmware from a different model? I really want to apply this patch! Thanks
11-02-2022 07:11 PM
Is that a U.K. based model? I thought they only did up to 75 inch in Q90t model in U.K. but I maybe wrong.
11-02-2022 07:11 PM
Hi.just put q80t and use that
11-02-2022 07:20 PM
I would assume not, I'm US based and the number was taken directly form the TV
