"Network Cable Connected" Notification.
(Topic created on: 30-10-2020 09:09 AM)
Ranger176
TV
I have a QE55Q90RATXXU.
Quite often (once or twice a night) we get a Notification, in the top right hand corner of the screen.
It says, "Network Settings, Network Cable Connected". It then gives the option to "OK".
The TV (one connect box) is connected by a good quality Ethernet cable to a network Switch, which is then connected to my Sky router, with a speed of about 37mbps.
Watching films on Sky Cinema, Netflix and Rakuten, are rock solid with no dropouts.
Why am I getting this notification? Please see photo attached.
Thanks.
12 REPLIES 12
TMSmalley
TV
I’m having the same issue. New TV bought just before Thanksgiving. “Network Cable Connected” message in upper right corner. I click OK and it goes away for awhile but then comes back after 20-30 mins. Did you ever figure this out my?
BBB243
TV
New Q95, same issue. A solution from samsung would be nice.
Tribefan43
TV
Same issue here...wish there was an answer
GTone
TV
Same here…
2021 QE75Q800T.
The worst is that I have no Ethernet cable connected.
I’m in Wifi, box in the same room and 800mbps connection.
AndrewL80
TV
Same here. I’m on Wifi and get the same error
trojanac
TV
SAME HERE SAMSUNG QN95A 😞
kingprawn007
TV
Same here as well qn95a
AndrewL80
TV
Same here, Au8000 65. Had the tv for about a year and does it. Been following this thread for that long hoping Samsung would reply with an answer.
GTone
TV
Is there any Samsung forum administrator or representative out there ?
Or is it just a feed board for pissed customers ?
