Go to solution Solved
QLED TV with Nintendo Switch
(Topic created on: 13-12-2017 10:23 AM)
Rossy100
Hi all
Just got my Q8 QLED TV which is awesome.  However I am having issues connecting to my Nintendo Switch.  The only way I can get it to work is if I set the Switch to output at 480p (which means screens are really low quality).  If I set to auto, 720p or 1080p the menu screen will eventually display, but will come up in a light blue colour (as opposed to white) and is flashing/distorted.  I have tried changing the HDMI cable but made no difference.
Anyone got any ideas how to fix this???
Thanks
Rossy100
Solved!.... Reset the TV and re-setup everything and now all is working!
3 REPLIES 3
Rossy100
7alhoul
Navigator
Hi Rossi100,
You can test your Nintendo Switch on another TV to find out what's coming from the TV or console.
nadavxcube
hello ,i didnt have this problem however- im using this settings on my qled with the nintendo switch hope u like it:)
https://www.youtube.com/watch?v=VN7G11QPGew
