Support
Open search
Samsung EU43MU6179 - issues with Netflix and Plex playing
Highlighted
SOLVED
Hello all,
I've used till now an Apple TV for Netflix/Plex for tv shows/movies.
As I've buy a new Samsung TV MU6179 I've added these apps into my TV as well and I started to watch tv shows and movies.
Now, my real issue (hope explain well):
as much as the sound is ok, the image while playing (more for Plex less for Netflix) suffers from...unatural movement of the characters from the movie/tv show - like some frames are loosed somewhere and characters/actors are moving too fast or too slow from time to time during one scene.
For sure I'm observing well but...it's a bit strange!
Just to precsie: it not happens this using an external player like Apple TV for example!
Internet band is good around 50 mb/s I think.
Any advices?
1 ACCEPTED SOLUTION
Highlighted
Hello,
Which cover you really refer to?
I've solved my issue by setting Picture Style = Movie from initial value = Standard.
The issue I faced is called 'soap opera effect'.
Thread could be closed.
3 REPLIES 3
Highlighted
Navigator
Hi katanel,
you can try emptying the cover of your TV by pressing the power button until the TV turns off and on again.
Thanks
Highlighted
Hello,
Highlighted
Hi @katanel. :robothappy:
I've marked your above post as the solution. Let me (or one of the other moderators) know if you'd like to change this.
 Say "Hello!" to the Community in The Introduce Yourself Thread.
Top Liked Authors
