14-12-2020 05:33 PM in
TVHello all, does anyone else have a setup where by they use the earc system to transfer audio to their AV amplifier?
If I switch HDMI earc to Auto in the menu system there is a horrible popping clipping sound when the audio tries to sync. This can be heard at all levels, changing programmes on Samsung TV, browsing Netflix movies and even when watching a Blu Ray via earc.
If the HDMI earc is set to off utilising the normal ARC then the audio is fine. There are no pops or clicks.
The problem with this is switching HDMI to off means you cannot pass through the hi resolution audio codecs like Dolby Atmos.
If you have had similar issues id love to hear from you.
Thanks.
30-12-2020 09:55 PM - last edited 30-12-2020 09:56 PM ) in
TVI had been having audio dropout and glitches using eARC on my new Q90T and had been disabling it as you describe to avoid this. I did find something that appears to have fixed eARC for me though. Go to Settings -> Sound -> Expert Settings, and set Digital Output Audio Format from Auto to Pass-Through.
30-12-2020 09:58 PM in
TVThanks for commenting, I’ve tried everything even what you have suggested but there is no stable outcome.
I’m waiting for a call from support in the new year so I do hope that Samsung can fix this.
For now though, earc will remain off for me.
