Q8F - How can I tell if HDR is on
(Topic created on: 06-12-2017 08:51 PM)
I have this problem too
TechnicPuppet
Is there a way to tell what type of picture I am watching. I've read that a lot of TVs pop up and tell you or have an info button tell you but nothing happens on my Q8F.
1 REPLY 1
Phil12
Voyager
Hi
I can tell usually because the back like ramps up to 20, by default on normal content it's lower than this.  So if you go into your picture settings when playing HDR content it should ramp the brightness up to max.
Note that a lot of YouTube footage claiming to be HDR seem to be copies of demo clips re-uploaded and have lost the HDR meta data.
Regards
Phil
