Go to solution Solved
Q80C - Sound drop-outs on digital TV
(Topic created on: 22-03-2024 06:06 PM)
dartiss
I've had my Q80C for a few weeks now with no issues with various devices that are plugged into it. However, I've just started using the digital TV option, via a roof-installed TV aerial. The signal is 100% and there's no drop-out from the picture at all. However, every 5-10 minutes (sometimes more often - basically, ad-hoc) the sound will go off for less than a second, but always noticeably so. The same issue isn't occurring with any other source.
Does anybody know what could be the issue? What can I try?
shtirliz_dev
5 REPLIES 5
Gurky
Helping Hand
Do you have other TVs connected to the same Aerial, issue seems more that side if all others apps and service work.
dartiss
I don't. I do have a digital box that I'm wanting to retire (which is why I'm trying it out on the TV) and there's no such issue if I plug the same aerial into that. It certainly seems to be TV specific.
Gurky
Helping Hand
Odd, check for software updates online the TV update usally is 6 no the behind.
shtirliz_dev
BrizzleRocker
