20-03-2021 04:39 AM in
TVI am trying to make the PS5 recognize the 4K 120hz video output, what I am doing I connect the PS5 into the Game port for AVR-X2700H and then connect to the:
1)eARC port on the Q80T television
2)Game port on the Q80T Television
then on the HDMI on Denon I also made the 8K enhacement configuration but when I looked in the PS5 I can´t see 4K 120hz as an available video output, is there someone who face the same issue know what to do in order to fix it?
21-03-2021 03:40 PM in
TV@Oblesrczuk: Please be advised that 4K @ 120hz is only available on HDMI port 4 on your Q80T TV. With this in mind you may wish to connect the PS5 directly to HDMI port 4, and set up the Denon on another port, or try connecting the Denon to port 4.
21-03-2021 03:44 PM - last edited 21-03-2021 03:45 PM ) in
TVThanks @AndrewL I will check if it will works if I use PS5 direct to the TV connected through earc
21-03-2021 04:04 PM in
TVI just made a test connecting the PS5 into the 8k port in Denon and on the Game port HDMI 4 and works but probably I will not have the eArc capabilities so I will need to go through the solution that @andrewL mentioned
