Go to solution Solved
Problem with browser on samsun smart tv ue55d8000
(Topic created on: 08-06-2018 03:09 PM)
dadolino90
I have problem with browser on my tv ue55d8000
when i start my browser and search example for youtube or any other site it shows me like server not found and in the right uper side stands a padlock. I was trying to update my software and there was no software for my tv. I am searching now to update it via usb but i dont know where to find the firmware update file. I was trying with some of them but my tv didn't recognize it on usb. Please if someone have a link for download. Firmware version now 001009
AndrewL
Hi @dadolino90
You may encounter issues while accessing streaming sites such as Youtube on your TV due to the absence of a flash player. With this in mind I'd recommend checking Samsung Apps in the Smart Hub menu to see if Youtube is available in this location. Regarding the update, please check the following link and scroll down to 'Downloads' to find 'Upgrade File(USB type) ver 1033.2 (MULTI LANGUAGE)': http://www.samsung.com/uk/support/model/UE55D8000YUXXU
1 REPLY 1
AndrewL
Hi @dadolino90
