Possible to change No Signal Screen to something less bright?
(Topic created on: 07-12-2019 01:09 PM)
Kornkamerad
Whenever I lose signal (relatively frequently as I use PC input a lot), the "No Signal" screen comes up. It is way too bright and illluminates my whole room. This is especially annoying at night when it kills your eyes.
Is it possible to change this screen somehow? I would prefer a much darker version (non animated preferably).
7 REPLIES 7
AndrewL
@Kornkamerad: Please can you confirm the model number of your TV, located on the sticker on the back of the device, and I will look into this for you. In the meantime please go to Home > Settings > Picture > Expert Settings and adjust the Backlight,
Contrast, Brightness, Sharpness, Colour, or Tint (G/R) settings manually to see if this helps.
sergnh
You answering some other question.
The real question is about this "screensaver". How to change it to something dark?
TCr83
I'm surprised to see no one else has responded to this. The 'no signal' screen is way too bright and impossible to look at in a dark room or at night. I, too, use a HTPC as input a lot of the time and this screen really bothers me a lot. The same issue with a Playstation or really any other device that switches on and off a lot.
Samsung, please make it possible to at least give us the option to change this into something dark!
jonpb
I would like to turn the screensaver off completely. If the screen is black, it's pretty obvious the connection is off.
p82n3doin23ld8n
I have the LS32BM801UNXGO and the no signal screen drives me nutty. I have a nice photo slide show screen saver on my computer, but at the very moment the time is up and my computer goes to sleep mode BRIGHT BLUE NO SIGNAL SCREEN. It's obnoxious and I want an option to have it disabled with the ability to turn off without a blue screen error timer. I don't need an error message EVERY SINGLE TIME my computer goes into sleep mode. 🙄
darthcody
Hi, I know its been a while since this was posted, but I was having this problem too and found a solution. If you go into the accessibility settings you can turn on the high contrast mode and wouldn't you know it inverts the color scheme on the no signal screen too. I was surprised it actually worked and I'm pretty annoyed I didn't try that earlier.
tasharoo
Thank you Darthcody!! I run my record player via the TV/ soundbar and for the past 4 years I've had to endure this annoying bright blue 'no signal' screen illuminating the room whenever I play a record. Never thought to look in this part of the menu. Selecting "accessibility" and then "picture off" removes the blue screen and allows the sound to continue. Amazing!! 😊
