Possible Fix for Too-Dark Netflix Videos on Samsung TVs
(Topic created on: 10-07-2019 09:26 PM)
100pat
Pioneer
Sadly, the answer is to switch your device to SDR. You can sit in a pitch black room and mess with settings all you want - that won’t fix it.
This means that you have to notice, or know, that the video you want to watch will be streamed  in Dolby Vision HDR and change a setting every time (then change it back - what a pain!) to accommodate this.
a) *EDIT* THE INFORMATION IN a) BELOW IS WRONG. I HAVE LEFT IT IN PLACE SO AS NOT TO CONFUSE PEOPLE WHO SUBSEQUENTLY RE-READ IT.  IT APPEARS THAT, FOR MORE MODERN TELLYS AT LEAST, THE OPTION ("INPUT SIGNAL PLUS" IN SETTINGS/ GENERAL/ EXTERNAL DEVICE MANAGER) FOR TOGGLING BETWEEN HDR AND SDR ONLY FUNCTIONS IF YOU ARE WATCHING VIA AN EXTERNAL DEVICE SUCH AS AN APPLE-TV OR A FIRESTICK.  IF YOU ARE USING THE TELLY'S OWN SMART NETFLIX APP THERE APPEARS TO BE NO OPTION TO TOGGLE BETWEEN HDR AND SDR.
a) If watching via the Netflix smart app on the Samsung HDR telly itself, turn off the HDR settings in the telly’s General/ External Device Manager settings which set the input ports for HDR. Usually called HDMI UHD Colour or Input Signal Plus. (EDIT: NO, THAT WON'T WORK. )
Now the Netflix Dolby Vision HDR video will still play in 4k/UHD but only in SDR. (And only in 8-bit) But, at least, you can see it without having to sit in the coal cellar.
 (May cause unwanted changes to other devices connected to the TV)
Remember to turn those settings back on again for non-HDR Netflix videos and for all Amazon etc. videos.
b) If watching via an AppleTV 4k connected to a Samsung HDR TV the following are usually the best Video settings in the AppeTV for everything except Netflix HDR videos. I recommend using them all the time:
- 4K SDR (Yes, SDR!) in 50Hz (UK) or 60Hz
- Chroma 420 (To enable 10-bit on most, not-super-expensive, Samsung tellys)
- Match Content > Range and Frame Rate both turned on.
Now, to watch a Netflix Dolby Vision HDR video in SDR on a Samsung HDR TV, simply turn off Match Dynamic Range (only) in the Match Content setting referred to above. EDIT :SO LONG AS YOU HAVE SET YOUR APPLE-TV TO SDR AS I HAVE RECOMMENDED ABOVE.
Now the Netflix Dolby Vision HDR video which you want to watch will still play in 4k/UHD but only in SDR. (And only in 8-bit)
Remember to turn that Range setting back on again for non-HDR Netflix videos and for all Amazon etc. videos.
EDIT: NOTE THAT, IF YOU ALTERNATIVELY ELECT TO TURN OFF HDR WHEN USING AN APPLE-TV BY USING THE "INPUT SIGNAL PLUS" SETTING IN YOUR SAMSUNG TV SETTINGS, THAT WILL WORK BUT THEN YOUR APPLE TV WILL SENSE THAT IT IS NO LONGER CONNECTED TO AN HDR TV AND WILL PROBABLY ALTER SEVERAL OF IT'S OWN SETTINGS.
EXPLANATIONS:
Firstly, the “best” AppleTV settings shown above will allow SDR Videos and the Home Screen to display correctly and then, when you start to play any HDR video, the AppleTV automatically switches itself to output HDR ( and automatically back to SDR again, when done.) EDIT: UNLESS, OF COURSE, YOU HAVE TURNED OFF THE "MATCH RANGE" OPTION IN ORDER TO WATCH A NETFLIX DOLBY VISION VIDEO.
Netflix outputs it’s HDR videos in Dolby Vision HDR format. Many brands of  telly display this OK but Samsung tellys are designed to use the rival HDR10+ format. Dolby Vision formatted videos display badly on Samsung TVs. Full stop!
Amazon Prime output their HDR videos in HDR10+ format so they display nicely on Samsung tellys.
Netflix claim to output HDR in both Dolby Vision format and in vanilla HDR10 (without a +) format. Presumably, if we could get them to send HRD10 (without a +) format videos to our Samsung TVs that would fix the problem. But, I rang Netflix, and it seems (in a very vague conversation) that this is not possible unless our AppleTVs could somehow request it.
Dolby Vision vs HDR10+. Who will win the battle to become the industry standard?
Note that this correct AFAIK on 08/10/2019 and may change in future. Those of us who just bought new Samsung TV sets will be keeping our fingers crossed!
EDIT: MY APOLOGIES FOR THE EDITS!
369 REPLIES 369
Kettyo
Pioneer
Guys may you check out the movie "Christmas in the Wild" on Netflix in 4K HDR?
It has just about perfect picture quality on my side.
What about Netflix and other streamers simply usually make a horrible job with HDR? I can imagine HDR is usually done by some automatic algorithm at them and not an expert resulting in subpar content most of the time.
I never had any problems with real non-streamed HDR content.
LetMeTurnOffHDR
Pathfinder
To be honest I dont think that summing up the titles that look good does any good unless samsung is actually reviewing the issue.
We need to be able to turn the darn thung off immediately....
Kettyo
Pioneer
I agree that such an option in the TV would be good but if the issue is definitely with streamed content only and all non-streamed ones run perfect (on my side this is true) then streamers should find the real solution (switching HDR off isn't a real solution, it's just a workaround).
Also you might notice with all the dim content that the thumbnails in the bottom when you forward are bright, maybe even too bright while the actual picture is dim. Another fact making me tend towards the problem is HDR implementation in most of these streamed shows and not HDR representation by our TV sets.
Do you have problems with real physical HDR content?
LetMeTurnOffHDR
Pathfinder
Its both.
Both the content provider need to deliver proper hdr10 content and the tv must allow you to turn HDR off.
LetMeTurnOffHDR
Pathfinder
But again...
This is not netflix nor amazon, thus us Samsung's forum on which they can answer with a real solution: turning off hdr.
The content solution is a thing to be discussed with netflix, amazon, and disney.
ikramkhasim
Pathfinder
I noticed the thumbnails too and am thinking the same. It may be the app on the TV too because the Netflix apps on my Samsung Galaxy S9+ and Windows 10 play the same content perfectly but the TV doesn't. And the latest season of Sabrina is great but not the first one. So they must have done something on their end.
Kettyo
Pioneer
But again...
You're right.
Let's push here and at other manufacturer sites for a HDR switch and at the streamers for fixing their HDR services.
Kettyo
Pioneer
Are you sure they play in HDR?
Win10 plays in HDR only if you activate it specifically under screen settings. If i do that it will be just as dim as with the TV app. If you don't activate HDR mode the Win10 Netflix app will stream 4K SDR.
I don't know anything about the S9 so can't comment.
Kettyo
Pioneer
The latest season is still way too dim on my side.
ikramkhasim
Pathfinder
Yes both devices I have are capable of HDR. The app will display the HDR icon. I'm using a 4K Microsoft Surface Pro with Windows HD Color turned on. And Samsung Galaxy S9+ is HDR capable.
