Overscan still occuring on SD Freeview channels
(Topic created on: 12-07-2021 06:01 PM)
Sebastian Doe
Hello, my Samsung TV (UE43LS03N) has had overscan on the standard definition TV channels since it has been installed, however the HD channels don't have any overscan.
On the HD channels, you are able to enable and disable the "Fit to screen" option, but this is not possible on SD channels. The "auto wide" option does also not make a difference.
This issue was first raised on this forum in 2018 (here), but there has still not been a software update to address this issue. Does anybody on here have information to help me to fix the problem?
0 REPLIES 0
