One connect box displaying 3 icons error
(Topic created on: 08-02-2020 08:56 AM)
Ermir4
Hi,
im trying to connect the tv to one connect box but onlt the following 3 icons display followed by the smart tv icon and then a black screen. Seems to be on a loop. Does not reapond to remote control at all. Please help.7728A856-344C-40DE-9C3E-450AA7BB58D0.jpeg
1 REPLY 1
AndrewL
@Ermir4: Please can you confirm the model number of your TV? Did the One Connect box come packaged with the TV, or was it a separate purchase? Are you using the Invisible Cable to establish the connection? In the meantime, for a step by step connection guide, please check the link below.
https://www.samsung.com/us/support/answer/ANS00062213/
