11-02-2022 12:21 PM - last edited 11-02-2022 12:22 PM
Hi,
I bought sound bar Samsung HW-Q950A few days ago, and I can't see the volume bar on the TV, really annoying !!!
The stupid Samsung sound bar volume display is ON TOP of the unit so it makes it useless when we are sitting down the couch..
The TV is connected to the soundbar by using ARC HDMI, so the auto power on/off and volume controls works fine but is not showing what volume I am on which is really annoying.
Have anyone here experience the same issue or any recommendations which I can try? the TV is already running on the latest firmware...
Thank you for help
11-02-2022 12:42 PM - last edited 11-02-2022 12:50 PM
11-02-2022 01:13 PM - last edited 11-02-2022 01:57 PM
I have a different brand of soundbar which is the same. I'm not bothered though in having a visual representation of volume.
11-02-2022 04:21 PM in
I just try everything, no success.
With the sound bar JBL working normal.
Probably is bug in Samsung system HW-Q950A.
15-06-2022 10:48 AM in
I have the same issue with my A80J oled tv. I wrote both Sony and Samsung but no luck
29-06-2023 01:48 PM in
I have the same issue too. Song A80J and Q950A soundbar.
Issue is definitely not with the A80J because if I connect another soundbar I have no issues. Software bug in Q950A is creating this issue. Quite annoying.
