10-06-2022 07:38 PM in
TVI have a Samsung Plasma Display tv (ps-42q96hd) and am trying to find digital channels. I live in Sweden and I know for the fact that all providers support digital tv and requested everyone to switch to DTV!
But I can’t find any channels tv/dtv and I have checked the antenna cable.
Does anyone know what the problem might be?!
10-06-2022 09:01 PM in
TV11-06-2022 05:24 PM - last edited 11-06-2022 05:28 PM ) in
TVHi @fressivoir Try the Automatic scan again. Some customers have found that scanning after removing the aerial and then reinserting provides a solution when channels are missing and your manual tune may be accessible. In other words scan with the aerial removed when obviously no channels will be found, however this can reset the connection. You would then need to scan with the aerial connected again and see if this makes a difference.
If not resolved possibility that there is some issue with the aerial. However seems to be the case that in Sweden a limited number of free to air channels are available, additional channels available with Boxer. https://www.chillglobal.com/channels/boxer-play
You may find more information in the Nordic communities with regard to the particular digital free to air , this is the UK/Ireland one. https://eu.community.samsung.com/t5/nordics/ct-p/se
One Ui 4.0,Android 12 Official Version.
