12-12-2019 09:15 PM
My UE22F5410 loses all terrestrial channels after turning the set of. I do a retune to the correct parameters and all is fine, I can change channels with no problem. When I next put the t.v. on it says no signal, I do a retune and all is fine until the next time.
I have tried the aerial connection with another t.v. with no problems.
Any help appreciated.
16-12-2019 11:16 AM
16-12-2019 12:02 PM - last edited 16-12-2019 05:31 PM
Hi SaudA
My Broadcast settings are Primary: England, Secondary: Kent, Additional: N/A
This is the same settings as on my other Samsung T.V. which works fine on the same aerial outlet, and also the same settings I used before this problem arose.
As I said in my post I can change channels with no problems until I turn the T.V. off.
My software is 2126, I've tried updating to 2127 both via wi-fi and USB and it gets no further than 29% on both. I've tried many times.
I've also done a Factory Restore via the service menu to no avail.
Thanks
Keith
17-12-2019 01:09 PM
17-12-2019 04:13 PM
Hi SaudA.
Yes, I have tried with two different new USB's formatted to Fat32. I have upgraded via USB before with no problems.
I have decided that I have spent more than enough time over the past few weeks trying to solve this unsolvable problem and will use it as an expensive amonitor.
Thank you for trying to help.
Keith
