My Samsung Smart TV (QN90A) isn't connecting to wifi anymore
(Topic created on: 06-01-2022 09:34 PM)
verge
I recently had gotten the new Virgin Media Hub 5, everything had worked perfectly fine until yesterday where the tv had disconnected from the router. After a bunch of trial and error I was able to get it connected until this morning where it has been disconnected again - now I can't get the tv to connect anymore! (I know its a tv problem and not a router problem because every other device works fine)
List of things i've done :
Factory reset tv
Network reset tv
The classic unplugging the tv and plugging it back in
Resetting router
Manually put ip settings from the information i got off my router
Reentered my wifi password
Updating the software of my tv
Changing the DNS to 8.8.8.8 or 8.8.4.4
and probably more that i cant think of
Please help im begging!
2 REPLIES 2
xSteveuk
Mastermind
Hi,
This page maybe helpful
How to connect your Smart TV to a Wi-Fi network
https://www.samsung.com/nz/support/tv-audio-video/how-to-connect-your-smart-tv-to-a-wifi-network/
Jbells
I truly hope someone gets back to you with a response. I'm having the exact same problem have tried all of the same things you have and have still had no luck
