Go to solution Solved
My husband is very deaf and needs headphones for TV sound; however, I am not deaf and like to listen via the TV speakers
(Topic created on: 28-06-2017 06:27 PM)
nannypenny
Derek175
I have the same problem, I purchased a set of headphones that had an optical input, and an optical converter plugged into the smart box ( on the Side), TV sound stays on so I can listen on my Headphones and my wife listens to TV output. Hope this works for you
2 REPLIES 2
AntS
Hi @nannypenny. :smileyhappy:
Are you wanting to know if your current TV can do this, or are you wanting to find out which TV models do?
Derek175
